Unfortunatelly the site is not available to the public domain.
I'm using the Nadia template and into this template there are 3 moduls mod_j51gridgallery . At the moment when I click mod_j51gridgallery the link open a page under the same modul but I would like that the link substitute the modul. I would like that happen the same thing that when I click any command of the menu.
I am still not sure if I understand you correctly however may I suggest the following extension which allows for greater control of when and where your modules are displayed... https://www.regularlabs.com/extensions/modulesanywhere
