1. tuki
  3. Wednesday, 18 November 2020
Hello Ciarán. I use Nadia template, and my client asked me to fix (show) the menu / logo when we scrolling on page. I tried to add position: fix into the header_background. It solved to fix the menu, and the logo in desktop view. But on mobile / tabs, the menu, and the logo is on each other. I cannot figure out how to position them with css to get the original order (menu, after logo), but be fixed on scrolling.
Can you help me a little about this?
BIG thanks!
Peter
Hi Peter
Sorry to say, it is not possible to change this with CSS alone. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will make this change for you. For our reference please paste a link to this post in your email.
Sorry, I left the url. So you can check this here: https://medicalstream.hu/hu/
Thanks a lot!
Regards,
Peter
Thanks for the reply. I added this on desktop its super. But on mobile, the menu still disappearing. Can you help me how to add also the mobile menu fixin?
BIG thanks!
Regards,
Peter
Hi Peter
.is-sticky #container_header {
transform: none;
#header_bg {
z-index: 10;
