1. Internetional
  3. Friday, 06 May 2016
I can't install Nadia-Demoinstaller on my localhost with xampp. The installation keeps on running with setting up data tables.
I haven't found any solutions so far. Does anybody know what I might do wrong?
Thanks and regards,
Marek
Hi Marek
Using the same database details (username/password/prefix) are you having similar issues with other demo installers or even the default Joomla installer?
I just tested the Nadia demo installer locally and seems to work fine so doesn't appear to be any problems with the installer itself.
I found the solution:
I had to change in joomla.sql
All "ENGINE=InnoDB" to "ENGINE=MyIsam"
and
in ini.php I had to set memory limit to 256M
in order to make sampel data installation work.
Excellent... thank you for sharing your solution! :)
