  1. luk
  4. Friday, 29 September 2023
Hello forum,
I need some help to modify my custom error.php to show a 404 depending on the language in my bi-lingual development site (NL and FR).
In a monolingual site (f.i. NL) I always use this error.php together with a hidden menu with a menu-item "niet-gevonden" set to NL, linked to the 404-article set to NL, and this works like expected.
<?php
defined('_JEXEC') or die;
if (($this->error->getCode()) == '404') {
header("HTTP/1.0 404 Not Found");
echo file_get_contents(JURI::root().'/niet-gevonden');
exit;}
Now with 2 languages (NL and FR) I have created two menu-items linked to each appropriate article in the hidden menu and this error.php:
<?php
$lang = JFactory::getLanguage();
$result = $lang->getTag();
if ($result=="nl-NL") {
exit;}
if ($result=="fr-FR") {
echo file_get_contents(JURI::root().'/non-trouve');
exit;}
But now only the NL-404 is shown and the expected FR-404 shows an empty page.
My PHP-knowledge is very poor, in fact zero, so I was inspired to this older topic: https://joomla.stackexchange.com/questions/15141/how-to-create-a-custom-404-error-page-for-every-language but obviously I missed something.
Any suggestions ?
Joomla 4.3.4 – PHP 8.1.21
  1. https://eltee.eu/devlcold/nl
Solved, with this error.php, which I want to share.
<?php
use Joomla\CMS\Factory;
use Joomla\CMS\Uri\Uri;
$errorPages = ['nl-NL' => 'nl/niet-gevonden', 'en-GB' => 'en/not-found', 'fr-FR' => 'fr/pas-trouve'];
$languageTag = Factory::getLanguage()->get('tag');
if ($this->error->getCode() == '404')
echo file_get_contents(URI::root() . '/'
. $errorPages[$languageTag]);
exit;
Where "niet-gevonden", "not-found" and "pas-trouve" are the menu-items with the appropriate articles, in a hidden menu.
Note that the country code must be added before in the URL, f.i. en/not-found aso
Hi Luk
Thank you for sharing your solution. I dont believe I realised this was possible... every day is a school day :)
