I am using the Metropolis (newest version) in Joomla 3.2.3. I notice that the menu is using mootools which makes my bxslider (jquery script for slideshows) to be unusable. As soon I disable mootools from site, the slideshows are working just fine, but the Menu stopos working as it should.
Knowing the fact that the Mootool library will be eventually removed from Joomla, shouldnt be usefull to use something like bootstrap or even jquery for the Menu?
I try the Jquery easy plugin hoping that it will help me out, but unfortunately it didnt. I also noticed that the problem is occure when I am using Chrome, Opera and Explorer (all in newest versions). In Firefox I have problem only if I make a soft refresh (F5). If I do a hard refresh (CTRL+F5) everything is fine. I check it in different computers, all the same problem.
The module that I am using with bxslider is the Phoca Gallery Slideshow bxSlider .
I hope for a solution soon, because the site is nearly to get online!!
