1. paolo
  3. Wednesday, 04 April 2012
Hello, I have a problem with template J51 Choice. The menu doesn't have the fading effect that should have with the menu tag ID moomenu in the advanced options of the menu module.
Also the j51 Thumbs gallery module doesn't work correctly; it displays the image in an empty page of the browser, instead of displaying it in gallery style.
Maybe the two problems are linked.
You can see the website here
http://213.174.168.61/abrex-system/
(Joomla 2.5.3)
I installed both the template and the gallery on a local server with a new, empty joomla 2.5.3 installation, and they both work fine.
What can I do?
Hi Paolo
May I suggest send temporary administration access to your Joomla installation to info@joomla51.com and we will investigate this issue further.
I just sent the email with the access to the website.
Yesterday I upgraded to joomla 2.5.4 and nothing changed about the menu and the slideshow.
Hi Paolo
Everything appears to be set as it should. I suspect the issue is related to accessing your site via the IP address and will be resolved once you access your site via a domain name.
I'll try in the next days. In the meantime... Happy Easter! :)
The web site is online here
http://www.abrex-system.com
but the moomenu still doesn't work :(
Could I ask you to send us temporary administration access again to info@joomla51.com and we will see is there anything else that may be causing the issue.
Email sent.
Hi Paolo
May I suggest unzipping the attached file into your templates html folder (../templates/j51_choice/html).
Great! It works! Thankyou very much!
What was the problem?
Great.. it was an issue with the moomenu script and how it handles seperator menu items.
