Hello, after update from some components the moduls on my site didn´t work right. When i reinstall the moduls it will work for a moment. When i cklick some buttons on the side the moduls didn´t work and look right.
http://www.colors4life.de
first pictures are the wrong ones ... last two pics is right.
Greatings Alexnader
			- colors4life
 - Friday, 09 April 2021
I have enabled conservative caching and have repeatedly testing navigating through your links. So far this appears to have resolved the issue.
				the arrangement should look like this - screenshot attached
				hello, sophia doesn't work for me either. if you click on "Leistungen" and then again on "Hallo" or the logo, the display of the ICONS and the news preview is no longer correct. See the attached screenshot.
I notice that you have replicated your template (Colors4life_j51-sophia). Have you made any customisations to this template as the default template (J51_sophia) appears to work without issue?
