I try to set manual the "Bottom 1 Module Width Settings" in "Extensions -> Template Manager -> J51_Oxygen", but if I set the 1st ena the 6th position to 50% and the outher to 0% i see only the position 1
Why???
http://www.thegate.it/joomla254
thanks in advance
- dado73
- Free Templates / Extensions
- Tuesday, 19 June 2012
Accepted Answer
Pending Moderation
it is not empty have a javascript inside like this
var uri = 'http://impit.tradedoubler.com/imp?type(js)g(19782722)a(1804585)' + new String (Math.random()).substring (2, 11);
document.write('<sc'+'ript type="text/javascript" src="'+uri+'" charset="ISO-8859-1"></sc'+'ript>');
</script>
and the layout is set like image
</script>
This script appears to be in the first module but not the sixth. According to your HTML the sixth module is still empty.
Accepted Answer
Pending Moderation
the script is very similar, but I confirm that are a banner in position six named bottom-1f.
if not disturbing, I can send you admin password via pm
Thanks to the availability
It possibly an issue with your script (by default Joomla will strip any code within <script> tags) Both modules exist on your page its just the 2nd one is empty, you should find that if you replace your code with some sample text it will appear as it should.
Accepted Answer
Pending Moderation
I'm try with sample text in position bottom-1f, but doesn't work.
The possible solution is not to leave empty modules together (insert module in order a, b, c, ...).
thanks
thanks
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will take a look for you.
Setting the position of your 2nd module to 'bottom-1b' appears to have resolved the issue.
- # 9
I too am having trouble with position bottom-1f. I can't get anything to display in this position and I need all 6 positions in the row. I turned on position preview and noticed that the position is labeled as "b0ttom-1f[mod_standard outline]" with a zero, instead of the letter o. Would this be the issue and if so, how do I fix it? Thanks.
- # 11
Shortly after my last post, I found the issue. Inside the file \j51_novation\php\layouts\bottom_modules.php I did a search for b0ttom and found the line that was wrong. I changed the zero to the letter o and the position works now.
- # 12
Hi studman11
Thank you for bringing this to our attention. The template has been updated with your amendment.
- # 13
