1. put.dirk@icloud.com
  2. News / Announcements
  3. Friday, 17 September 2021
Dear,
Do you know when the upgrade for the modules are coming? In my joomla admin it mentions that version 4 is available but the next mentioned modules are not yet compatible.
J51_ThumbsGallery Module 1.1 No Compatibility Information No Compatibility Information
J51_News Module 3.0.0 No Compatibility Information No Compatibility Information
J51_InlineIcons Module 1.0 No Compatibility Information No Compatibility Information
J51_Icons Module 2.0.14 No Compatibility Information No Compatibility Information
J51_SlideshowModule Module 1.0 No Compatibility Information No Compatibility Information
J51_Carousel Module 2.1.1 No Compatibility Information No Compatibility Information
j51_kaylee Template 1.0.8 No Compatibility Information No Compatibility Information
Kind regards
Dirk Put
Good question, and I would like to see an answer soon. At present I have a couple of sites that use the J51 templates and plugins that will require updaing to Joomla 4 before Christmas.
Hey guys - running a test build of J4 with J51 Nina quick start and all those extensions are in it and working. (obv not the template)
Is J51 ariana running with Joomla V 4? In the moment an update to Joomla V 4 will destroy my web! :-(
  3. # 3
Quote AlisonAMG: (obv not the template)
J51 - Nina is (at the moment) the only template for J4 - and moreover there is a seperate version for V3 and V4.
  3. # 4
Hi Chris
Yes I understand that. I am running Nina 4 using the quick start install package (vs just Nina 4 on a bare J4 install).
  3. # 5
Ali, that's a misundestanding. I was referring to
'Is J51 ariana running with Joomla V 4? In the moment an update to Joomla V 4 will destroy my web! :-( '
That's why I said that there's only Nina for J4 at the moment.
  3. # 6
Thanks Chris - I wondered when I read over the thread.
  3. # 7
