1. pauldesign
  3. Sunday, 21 September 2014
I am using the renovate template and have placed content in the top 1a module. The content shows fine on all pages except on one page it is compressed.
I have looked into every module to see if there is a position with something in it that is causing the top 1a module to compress. But I am unable to locate it. Frustrated.
Here is the website domain: http://www.awarehtaf.org
The problem is on the action awareness campaign page. On the donate page and other pages, their is no problem. Can't figure it out.
Hi Paul
A number of possible causes but probably the most likely is that you have 'Manual Widths' turned on within your templates parameters, with this particular module position set to 33% width?
Thanks for the help. The width was set at 33%
I have about 3 renovate template styles. Some have the width set at 33% and others do not.
It gets confusing. I am creating a paper log of the whole site to keep track of all the items on the site.
Appreciate your help.
Hi Paul
May I suggest the following tutorial which details the module widths feature available in the templates parameters... http://www.joomla51.com/tutorials/item/understanding-the-module-widths-options
