Hi, I don*t find the solution to change the color of the module title. of course there is the possibilty in styling to change it. but nothing happens...
thank you again for youf assistance.
Have you multiple template styles on your site (Extensions -> Template Manager)? If so ensure that you are editing the correct template style for the pages you wish to edit. This is the most common cause of template changes not reflecting on a frontend page.
You had the following in your Custom CSS field which was setting your module title colors overriding the color set by the template, Removing the color has resolved the issue..
