1. Carrie Wrigley
  3. Friday, 27 June 2014
I notice that on your demo, a number of times the modules appear with just text for the title - which I like. When I create modules, however, in pretty much every position, they all have a thin grey line above and below the title. Which works great for some things - but not for others (as you model in your demo.)
Is there a Module Class Suffix or something that turns the lines on and off? In general, are there any style variations available for the modules?
Also - my favorite module on your demo is the one featured under the menu, as follows:
[center]Endless Styling Possibilities with a Wide Range of Color Choosers
Grafik allows you complete freedom in styling your template with a large selection of colour choosers for almost every element of your site.[/center]
As the demo shows, I'd like to be able to display a large title (without lines above and below) and small text underneath, in that same position, in a color and opacity I select. So - What module position is that "Endless Styling" module in; and how can I set the text style to match your demo? (without the lines?) I searched over and over throughout the demo, but couldn't find any information about how to achieve that look in the modules.
Top 2A - Ok, yes, now I see - Thank you!
I'll look into the slideshow question more next week - I have enough to keep me busy for now. I appreciate all your help!
Hi Carrie
1. This module was placed in the top-2a module position.
2. Not sure if I understand you correctly. Are you referring to the slideshow images in the example styles pages?
Yes, that makes total sense. Thank you!
Also - which module position did you use for the "Endless Style" message?
And - what size picture do you need to plug in for the photo-based "styles?"
Hi Carrie
In some cases when we did not want to use the default module title we would disable the title and then add our title text to the content of the module instead. To do so simply add your text with in H3 tags (Heading 3).
In the 'Endless Styling...' module we set this text to the slightly bigger H2 (Heading 2), once again disabling the module title.
I hope this makes sense?
