1. erikoraka
  4. Thursday, 23 September 2021
I have the following two questions:
1. In the following url
https://www.arthrojoint.gr/joomla/eksidikefsi/2021-09-22-14-05-58/arthroskopisi-omou,
in the right side column I have added an module menu. Is it possible for this menu to work like an accordion?
For example is it possible only for the first level to be show and for the second level the user to press the little arrow on the left in order to open the drop-down list?
2. In the above url I would like the side column when scrolling down the article to remain still at some point so as always for something to be shown on the right.
For example see how the side column on the left behaves in the following url https://osteon.gr/tmimata/spondilikis-stilis/kili-mesospondiliou-diskou-diskokili/#diagnosi.
Thank you in advance!
Best regards,
Eri
For this you have to switch in the backend under Extensions -> Plugins and click there Content - Page Break.
There you only have to switch to Slider.
Accordion
Create a "custom module" and insert your menu items.
Example: Example
<h2>menu</h2>
<hr class="system-pagebreak" title="Dummy Page Break" /><hr class="system-pagebreak" title="Menu Item 1" p="" />
<p>Response menu item 1</p>
<hr class="system-pagebreak" title="Menu Item 2" />
<p>Response menu item 2</p>
Sorry to say but your answer did not help me :(
Your first suggestion if it was referred to question 1 did not work..
Your suggestion about the accordion seems too advanced..
Yes it refers to the question 1.
What is too difficult about it? You simply have to create a menu / module of the type own module.
Then you write the menu item in it and link them easily.
Example:
Your Menütitle 1
Pagebreak (read more)
Answer <- with link to your text
Your Menütitle 2
Your Menütitle 3
<h2>Your Menü</h2>
<hr class="system-pagebreak" title="Your Menü1" />
<p>Answer</p>
<hr class="system-pagebreak" title="Your Menü2" />
<p>Answer</p>
<hr class="system-pagebreak" title="Your Menü3" />
<p>Answer</p>
<hr class="system-pagebreak" title="Your Menü4" />
<p>Answer</p>
There you only have to change to Slider.
