1. newdyne
  3. Wednesday, 29 October 2014
I'm new to this process and would like to print out the module map for J51 Calibra template.
Is this possible?
If so, how can I do this?
Best Regards
Chuck
Hi Chuck
Presuming I understand you correctly a module map is included with your template. You will find this in the 'Template Extras' folder of your download and is called ModulePositions.png
You understood correctly.
I found it.
Chuck
