1. webmasto
  4. Monday, 05 September 2022
Hi, I updated my stio with joomla4, but the "icons" module does not appear in the home. "Layla" template. Help would be nice. Thank you
Hi, I've always done this, I had to uninstall the module and then install it. Now everything is OK. Thank you
Resolved:D :D
Hey Webmasto
The "icons" and other functionality are installed separately on updates. When you download and unzip the file you will find the quick start package as well as a folder with the template and all the plugins like icons. (similar to the image attached)
Hope that helps :)
