1. mediafrog
  4. Wednesday, 12 March 2014
Hi.
I use gridgallery in this page (template virtuoso):
http://www.fassadenbegrünung-brandmeier.de/index.php
the "on scroll animation" doesn’t work, is there a documentation how to do this?
regards
grit
Hi Grit
Could you confirm for me that you have the latest version of the template (1.1) as this feature was only added recently? The version can be seen in your template manager.
If so could you detail for us which element of your site you are looking to animate.
thank you for your message. my template is 1.0. When I now update the template to 1.1, I will lost all my settings, isn't it?
regards
grit
HI Grit
Installing the template will just replace your template files and have no effect on your template settings. No template settings will be lost.
Hi Cirian
I have now updated the template, but gridgallery doesn't work again.
Module
"Anwendungsbeispiele für Fassadenbegrünung"
picture 1 and 2 should work with gridgallery.
and a further question: gridgallery doesn't work on iPad. I tried your demo-templates. Is there a solution for it?
regards
grit
As there is no hover state on a mobile device the grid gallery images will simply be linked with no caption. There is no current work around for this.
Hi cirian,
sorry, it was my mistake. of course I had to update also the module gridgallery and not only the template. now it works fine.
thank you so much. :lol:
regards
grit
hi cirian,
I just wanted to work with the template and got the mistake:
mootools not found
I installed the version 1.1 again, but no changes.
please help!!!!
Where are you getting this error message?
hi
I wanted to make some changes in the template Settings. I hope you can help me soon, because my Client is waiting.
here are the admin-data
user: REMOVED BY ADMIN
pw REMOVED BY ADMIN
hope this helps you to find the mistake.
regards
grit
hi cirian,
I deinstalled now the template and installed it again. every thing is fine now. the settings are indeed lost, but doesn't matter.
now I have a further question. we don't want the header with the logo.how can I to this? If you could answer as soon as possible it would be nice.
regards
grit
Hi Grit
To remove just the logo you can add the following to the Custom CSS field of your templates parameters...
#logo {display:none;}
To remove the entire header area you can try adding the followng...
#container_hornav {
display: none;
I have an issue with the GridGallery.
All works fine, except on hover, nothing displays. I have content in the Image caption title and text fields.
I just removed the cashmere template and J51 gridgallery plugin and installed it again, still nothing.
I use Joomla 3.2.3
You can see my progress here; http://boenk.be/masizwanejoomla/index.php/accomodation
Greetings,
Erik
Hi Erik
I have the same problem as ErikHauters with Grid Gallery.
The content in the image caption title and text fields isn't visible on the frontend of the website.
I use joomla .3.2.2.
Greetings,
Jan
Thank you Erik
We amended the issue by adding the following to your templates CSS...
.j51gridgallery figure:hover img,
.j51gridgallery figure.cs-hover img {
-webkit-transform: translateY(-50px);
-moz-transform: translateY(-50px);
-ms-transform: translateY(-50px);
.j51gridgallery figure:hover figcaption,
.j51gridgallery figure.cs-hover figcaption {
opacity: 1;
-webkit-transform: translateY(0px);
-moz-transform: translateY(0px);
-ms-transform: translateY(0px);
-webkit-transition: -webkit-transform 0.4s, opacity 0.1s;
-moz-transition: -moz-transform 0.4s, opacity 0.1s;
transition: transform 0.4s, opacity 0.1s;
Jan: I suspect this will also resolve your issue. To use the above CSS simply add to the Custom CSS field of your templates parameters.
Thank you for the prompt response!
