1. RAMON
  3. Tuesday, 22 January 2013
I am very happy with his squad, but I have some problems, there is no way of solving I started painting with photoshop all files in the directory I images (GRAD1, head, iphone-off, iphone-slider, base_bg, bg, content_bg, hornav, read and shade), but I have all the modules in the edge of the gray attached photos, plus a few items on the menu are also in gray, is there a solution I stopped painting put something ..... link .... Greetings and thank you very much
http://www.donabela.es
Thanks, thanks, the video module WebPlayer causing the problem, if you turn off the menu works correctly. Is there any solution has this problem, thanks again
There sould be a conflict with one of the modules you are using on your homepage. Try disabling each module until you find the culprit.
If the problem is always from the main page (PORTADA), if click on another main menu item, the dropdown works slower and better?????
  3. # 3
Appears to be just an issue with your homepage. Are you finding this issue on other pages.. for example.. http://www.donabela.es/index.php/fiesta ?
  3. # 4
Thank you very much again, it works fine, but I have a query on the menu last OUTLET, the drop is very fast, and it is difficult to reach the option € 295, € 495, etc, and it is almost impossible to click, some form of make them slower or more static these dropdown menus ....... Thanks again and best regards
  3. # 5
Hi Jaime
Culd you detail for me what you would like to achieve?
To change the color of the background to your dropdown try adding the following to the Custom CSS field of your templates parameters..
[code type=css]#hornav ul li ul {background-color: #E6C5E9;}[/code]
  3. # 6
.module, .module_menu, .module_padding, .module_content, .subMenusContainer {
background: #e6c5e9;
border: none;
Hello, I have module_padding and modulo_content, and does not work (with none), but if I put color if it works. Why?. Submenuscontainer The module does not work, do not get it .... A greeting and thank you very much for this beginner ......
  3. # 7
In the dropdown menu, for the home page comes in gray, and I want it in purple, in fact so I put it in the template configuration, but when I browse the template, I changed color purple, that solution there ..... Greetings again
  3. # 8
To remove the grey background of your modules try adding the following to the Custom CSS field of your templates parameters..
[code type=css].module, .module_menu {
background: none;
border: none;
}[/code]
Is there a particular HEX color you wish to change your menu dropdown to?
  3. # 9
