1. erikoraka
  4. Wednesday, 20 July 2022
In the following url: https://www.gw-wineroutes.com/en/ I am using the following css to change the color of the links in module base-1 only:
.base-1 a:link {
color: #9c9c9c;
As you will see for some reason some links change some do not change and appear with the default light blue color I have set in the template parameters.
Can you please advise?
Thank you in advance!
Eri
Hi Eri
To amend, try also adding the following...
.base-1 a:hover {
color: rgb(255, 255, 255);
Hi Eri
To amend try changing your custom CSS to the following...
.base-1 a {
color: #9c9c9c;
Thank you for your reply.
The only thing now is that in this way I lose the link effect that is when I place the cursor on the link it does not change color a bit, something which is usually done with links..
Ideally the effect I would prefer is like the footer menu.
If you have any idea on this also it would be very helpful!
