1. tiffgrooves
  3. Saturday, 07 April 2012
I wanted to place a contact form module within the "showcase" position, to the right (similar to how it would appear in the "sidecolumn" position). I adjusted the css to reduce the width of the slide show to 650px. Then I setup the module. When I put it in the "showcase" position, it places itself under the slide show and stretches across the entire section. What files / code could I modify to set its width at 250px and place it the right of the slider?
Thanks in advance for your help!
You will need to make some amendments to your CSS to allow your 'showcase' module position to accommodate your contact form. Would you have a URL to a page with both modules enabled so we can investigate it further?
Yes, thanks for getting back to me. This has completely stumped me. I tried adjusting the width of the contact form in firebug, but it still breaks. Here is the site:
[removed link]
Right now the contact form is in the sidecolumn position.
Could I ask you to place the login module in the 'showcase' module position so we can ensure the styling we add is correct to accommodate the 2 modules.
  3. # 3
Of course. Done.
  3. # 4
Try adding the following CSS to the end of your templates template.css...
[code type=css]#ajaxcontact {
float: left;
width: 240px;
padding: 40px 20px;
.NivoSzakiSlider {
width: 650px;
float: left;
}[/code]
  3. # 5
Yay! Thank you. I'll purchase the template now. Thanks so much for your help.
  3. # 6
