You could still place the search module in an alternative module position (Extensions -> Module Manager -> New -> Search) if you wish.
Another option would be to create a new module position with the following...
Add the following to your templates header.php (../templates/j51_executive/php/layouts/header.php) just after
 <div id ="header" class="block_holder">   (line1)..
<div id="newmodule">
	<jdoc:include type="modules" name="newmodule" />
</div>
You must then style it with the following which you can add to the end of your templates template.css (../templates/j51_executive/css/template.css)
#header {
	position: relative;
#newmodule {
	position: absolute;
	height:50px;
	width:300px;
	top:25px;
	left:660px;
	margin:0;
	padding:0;
	z-index:99;
Edit the above to your own taste (top, left. height, width)
And that should be it. You'll find the position won't be listed in the positions dropdown so simply type it in to create (
newmodule).
