1. WebsiteAK
  3. Sunday, 17 October 2021
Dear Cirian,
Shortly (I don't know exactly when, maybe/probably since the update to Joomla 3.10.1) the modules, I created with mod_j51slideshow don't appear on my website anymore.I really can't find out what is interfering or found someone with the same issue. Tried to research on your forum as well.
I have the Stockholm Template. I noticed you updated this in May 2021. So I updated the template & modules (which is of course always a good thing to do), but this didn't change anything unfortunately in the slideshow documents.
Do you have an idea what could be the issue?
Thank you so much in advance.
All best (also with all the hard work for templates which will work on Joomla 4. Great Job)
Annechien
In addition.
All my (almost) 100 J51Slideshowmodules are not working on the Frontend. I have doublechecked the settings of course
See attachment for an example how it now looks
What is left is the title of the Module and an arrow. But no photo appears, let alone a slideshow of the photos.
Hi Annechien
Dear Ciaran
I solved the problem through reading your advice on your tutorials carefully:
https://www.joomla51.com/tutorials/joomla51-extensions/troubleshooting-the-j51-slideshow
I had to disable an extension (and uninstalled it). That did the trick. Sorry for bothering you.
Thank you for your clear tutorial guidiance, will read it more carefully in the future.
All best
Annechien
