1. BulachFred
  3. Sunday, 23 October 2022
is it possible that the following module is not available in the Joomla 4 downloads?
Select your module install file (mod_j51menu.zip). This file can be found in your template download in the same folder as your template install file.
For which template are you having this issue?
I have the same question. I can not find the mod_j51menu.zip in the template folder. Is it not available any more for Joomla 4?
Its for the template Nina.
But as far I can see, it's in none of the templates I already bought from Joomla51.
Kind reagards,
Steven
Sorry to say but there is no mod_j51menu.zip module included with any version of our Nina template. Note that this module is for creating Restaurant type menus (eg. http://www.joomla51.com/demo/0167/index.php/module-extensions/menu-module).
