1. Digijoom
  4. Monday, 26 March 2018
I have the same issue as this https://www.joomla51.com/forum/selecting-images-for-layerslideshow
I did install the mod_j51layerslideshow from the template Artisan. But it won't help.
Mouse-over the eye icon in the module (List/Add Slide Image(s) doesn't show the photo anymore and the select and X function doesn't work. I tried it in Google Chrome and Firefox. Both won't work.
I work with Joomla 3.8.6 and PHP 7.1
Can you help to make it work again?
Kees
Hi Kees
Have you tried installing the latest download of your template module?
If so may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
Hello Ciarán,
I download the template again and installed the mod_j51layerslideshow over the existing installation.
I see that the layout of this module is changed and it works good.
But I lost all the settings from the old modules. Fortunately I was in my test surrounding.
How can I install the new version of mod_j51layerslideshow without destroying all the existing settings?
Best regards
Kees
Hi Kees
Sorry to say there is no way around this. Joomla changed from using the now deprecated repeatable fields (https://docs.joomla.org/Repeatable_form_field_type) to subforms (https://docs.joomla.org/Subform_form_field_type). Each of these fields store data differently.
