1. donsaydoo
  4. Saturday, 18 February 2017
Beaumont Template
The Showcase module shows beautiful building with writings overlaying each slide.
I go to module and i see the mod_j51carousel. There are no photos , i see only writings for the first 3 columns.
So where do i change the photos to mine? i have spent hours looking for this but no headway. Please , help, is urgent.
My bad. I was looking at a site I made with a different template...
In the Beaumont template you can set the images for the header in the template styling tab.
If you go to the module mod_j51layerslideshow you will find a tab 'settings'. First item on that tab is 'Slide Images' where you can click the button 'List/Add Slide Images'.
Can't be any easier
Voila !.
Great job. thanks
hello,
Thanks for the response, but there is no mod_j51layerslideshow in my demo installation. You can see from the attached image. But i have the slideshow working fine.
One last things, can i get the module positions diagram?
You will find a diagram displaying all the available module positions in the 'Template Extras' folder of your download (ModulePositions.png).
thanks for the effort.
However i have another challenge.
I want to put full width images in the showcase module for other pages apart from the homepage. i want the static image to look like the mod_j51slideshow that is full width. I have no idea where to do that editing in the css.
thanks
Have you tried simply using the J51 Slideshow module to display your single image?
ok. i would try and give feedback.
It does not work well either. It is seen in the screen capture attached.
Note that you can also set a background image to the entire header area via your templates parameters. From your Joomla administration navigate to Extensions -> Template Manager -> [YourTemplateStyle] -> Styling and set your header image via the field provided.
Please the mod_j51carousel text that appears, is in the middle of the slides. How do i push them to the bottom.
I tried pushing the text in the module using the ENTER key.
However, when i do so, the space between the ext and the bottom border, remains the same, hence increasing the height of the slideshow instead.
My client likes the template, except for the positioning of the Text on the slides.
Sorry i checked there is no provision for the header portion, it is top1, top2, top3, etc, but not header. So if you an show me exactly where to amend the header module to allow for wide image like the slideshow carousel on the homepage.
Also each page would be having a separate image
In the 'Styling' tab of your templates parameters you will see an option to set your header image(s). If this option is not available may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Different template settings can be used for different menu items by creating multiple template styles (http://joomla51.com/tutorials/item/creating-multiple-template-styles).
