1. maudo2
  3. Monday, 17 March 2025
I'm using j51_caitlin on the site https://roessle-hoerschwag.com, j51_willow on https://www.speicher-tuebingen.de.
On https://bio-ei-emmendingen.de i use a template from joomspirit (they no more exists).
Problem: on Mobile/Handy view i can resize the whole page (two finger slide) with the Joomspirit Template, but not with J51 Caitlin or Willow.
Are there options in the configuration, that i'v ignored?
Regards,
Markus.
No Idea??
Have you received my eMail on 17.05.? ;)
Markus.
Hi Markus
We do not appear to have received any details related to this topic. To amend try adding the following to the Head Custom Code field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom Code)....
<meta name="viewport" content="width=device-width, initial-scale=.5, maximum-scale=12.0, minimum-scale=.25, user-scalable=yes"/>
Hi!
Thanks a lot - that's it!!
Markus.
