24 HOUR FLASH SALE - 30% OFF EVERYTHING - Enter coupon code 24HOURFLASH on any purchase!
  1. FlexMax
  3. Tuesday, 25 August 2015
Jomsocial is in smartphones (responsive) my page is not displayed correctly. Why is this so ?
https://www.jomsocial.com/media/kunena/attachments/5510951/3_2015-08-22.png
Jomsocial said that the problem is on the template, and not to the component.
yes
Thank you FlexMax
Could I ask you to also include a URL in your information.
sorry i forget it :)
Thank you FlexMax
To amend could you try adding the following to the Custom CSS field of your templates parameters...
#container_main .wrapper960 div {
overflow: auto;
thank you first. The "buttons" are now no longer visible. but the following error is still there.
1) on the lower side is now the shift dial to see which one can move the "page" to the right, but that is not the optimal solution.
2.) when I click now put the marked, nothing shows on the left and right side.
Hi FlexMax
To ensure that each of these issues are related to the template could I ask you to enable one of the default Joomla themes (beez) and see if the issues persist. Any issues that are still present would indicate a more component related resolution.
with the BEEZ template it works great.
Thank you for the screenshots.
Firstly remove the suggested Custom CSS mentioned in the previous post. Then replace the following in your templates nexus.css (/templates/j51_enterprise/css/nexus.css)...
box-sizing: border-box;
overflow: visible;
With...
Perfect. Now its work great. thx so much
Great! Thank you for the update! :)
