1. GF
  4. Monday, 20 April 2015
Hello Ciarán,
I´m struggling with the mobile menu in the Cashmere template. It will not appear. Whatever I try. It works on a tablet in landscape but not on a tablet in portrait nor on smart phone in portrait or landscape.
I´m using the template also on another website without any problems....
Any idea???
http://www.rondreisinportual.nl
Hi GF
Could you check that the URL provided is correct as it appears to be giving us a 404 - Server not found error.
Sorry for the typo!
The URL is: http://www.rondreisinportugal.nl
There appears to be a conflict with one of your modules, specifically a module on your homepage. If you wish you can send temporary administration access to your Joomla installation to info@joomla51.com and we will try and located the extension for you. For our reference please paste a link to this post in your email.
I have sent you an email with the title rondreisinportugal.nl.
Thankx!
Thank you GF
As Joomla 3.x loads jQuery by default, we have disabled it within the slideshow modules parameters which appears to have resolved the issue.
Hello Ciarán,
I have the same problem with the Cashmere Template. It started happening after I upgraded the site to Joomla 3.4.1 April 16, 2015. I believe there’s a conflict with JSN Imageshow. I’ll e-mail you offline with login information.
Zie geen problemen meer is gelukt.
Site ziet er netjes uit en leuke gedaan, succes
Thank you Elaine
I have installed 'jQuery Easy' which ensures only one copy of jQuery is loaded across your site and your mobile menu appears to be now working correctly.
