1. nomore
  3. Tuesday, 20 October 2015
If I scroll down on mobile devices, the Mobile menu disappears.
How can I fix the menu, so that is always shown it.
Hi Ciarán,
Thanks for the quick response. this solves the issue!
Best regards, Joan
Hi Joan
To move your logo down you can also add the following to the Custom CSS field of your templates parameters....
#container_header {
padding-top: 40px;
Ciaran,
I tried this in Calibra, it worked but the menu is placed over the logo position.
Is it posible to put it above the logo?
Thanks, Joan
To fix your mobile menu try adding the following to the Custom CSS field of your templates parameters...
.slicknav_menu {
position: fixed;
width: 100%;
z-index: 999;
