1. paolofarina
  3. Monday, 27 April 2015
I have two questions:
1) when I check my website http://www.isamilan.com with a mobile, the menu show only "menu" and not all the other menu item
I followed the instruction: create a new module for each language with ID Class mobile...
I tried to set off all the third part plugin (they are just 2: JCE e Resourcer) but nothing happen
My core CSS is vergin, I only hadded new position for language switcher following instruction of your tutorial.
Check with italian language that have more menu item.
2) when I check the site with mobile, there is too much free space between logo and menu, I attach a screenshot to better explain.
Thank you Ciaran.
Paolo
Hi Paolo
Your site appears to be offline. Could you send us temporary access to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Thank you Paolo
1. Select a Template style in your 'Template Manager' (Eg. Central - Default) and duplicate it for each language you want. In each of the styles then select the menus to be displayed for that language. You can then set that template style to the langauge via the 'Languages' dropdown or by assigning the correct menu items via the 'Menu Assignment' tab.
2. To amend try adding the following to the Custom CSS field of your templates parameters.,..
#nav-toggle {
top: 58px;
text-indent: 999px;
for the first point is ok :) :)
Now menu items in mobile are visible.
But for the second question nothing change.
I think is better if you check the custom css i added because I'm afraid that your code would be in conflict with code taht I added in the last days.
Thank you Ciaran, come potrei fare senza di te? (How can i do without you?)
Paolo
Hey Paolo
To resolve could you also try adding the following to the Custom CSS field...
.js #nav {
top: 68px;
Sorry Ciaran, but still doesn't work.
I did a mistake, is not calibra, is Pianoforte.
Sorry
Paolo
Hi Paolo
The last suggested CSS does not appear to in included with your Custom CSS (English template style). We tried adding the CSS ourselves with the access details provided however connection with your server appears to constantly reset, preventing us from doing so.
sorry Ciaran,
I erased your account.
Now you have your older account to access
Paolo
Hi Paolo
Sorry to say we are still unable to access your administration (username: ciaran).
try now
Paolo
I send you an email with the link to access to the backend
Paolo
Thank you Paolo
We have added the suggested CSS to your Custom CSS field of each of your template styles and your mobile menu appears to be now working correctly.
sorry there is still too much space between logo and menu bar in mobile view.
I attach you a screenshot to better understand.
My apologies... I had mis understood your original query.
Try adding the following to the Custom CSS field of your templates parameters to reduce your header height on smaller screen devices...
#container_header {
height: 180px;
#container_header_bg {
top: 120px;
#nav-toggle {
top: 0px;
.js #nav {
top: 9px;
PS. Once again we are unable to access your administration.
Yahooo, it works.
I customized it, now I have to put on all the templates for each language.
Thanks Ciaran.
Paolo
Great!!.. thank you for the update :)
