1. alfoto2
  3. Saturday, 17 May 2014
I'm having an issue with the mobile menus, they don't show if my cookie alert module is enabled. The cookie module is set to position newmodule.
The newmodule position has been added to header.php as
<div id="newmodule">
<jdoc:include type="modules" name="newmodule" style="none"/>
</div>
It seems the hornav-mobile position and the newmodule one are similar or one prevent the other to appear?
If I disable the cookies module mobile menu works fine again.
Thanks in advance.
yes, please take a look at http://www.albumds.com
Your cookies alert module appears to be loading jQuery causing a conflict as this is already loaded by the template. Try disabling jQuery for this module to see if it resolves the issue. Alternatively you can install 'jQuery Easy' (http://extensions.joomla.org/extensions/core-enhancements/performance/jquery-scripts/18327) which will ensure only one copy of jQuery is loaded across your site.
I have installed jQuery easy and after some tests I found that setting "Strip No Conflict Code" to NO helps, it seems to work now.
The responsive menu button is almost completely hidden below the cookie alert but once you accept cookies it's visible and working.
