1. kevinfrehill
  3. Thursday, 19 June 2014
I was trying to change the colour of the mobile menu background from black. I went into responsive.nav and edited this line. background-color: rgba(0,0,0,0.4); It caused the menu to stop working and the background to go away. I changed it back to the original code but it won't return to normal. Please see attached screen shots. The url is http://www.castlefergusequestrian.com. The template is letterpress.
Thank You,
Kevin Frehill
Problem solved by reinstalling template. But I did try and modify another colour on the menu and the same thing happened. Is there anyway to modify colours of menu without this happening and why is it happening?
Kevin
Hi Kevin
To edit the background color of your mobile menu try adding the following to the Custom CSS field of your templates parameters where #444444 is your new background color (edit to taste)...
.slicknav_menu {
background-color: #444444;
I tried that but it doesn't seem to be working with the Calibra template. Morover, I'd like to get rid of the rollovers that imho. are somewhat useless on a finger operated mobile device.
Thanks.
Thanks Caran problem sorted.
Kevin
Kevin: Great!.. thank you for the update!
cuervo: Would you have a URL to an example of your menu?
Hi Cuervo
We are failing to the see the suggested custom CSS in your source. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will add the custom CSS for you. For our reference please paste a link to this post in your email.
I tried that also but it doesn't seem to be working with the Virtuoso template.
Gr Edgar
Maybe try setting !important to the CSS property like so?...
.slicknav_menu {
background-color: #444444 !important;
No sorry, it is still not working
Will do, tank you Ciarán.
Thank you cuervo
The following CSS has been added and appears to be working correctly...
.slicknav_menu {
Tanks Ciarán, I appreciate.
