This is how site http://www.andrijasevci.hr looks on mobile devices. Content is too small to read. Looks like shrinked version of full site - not responsive as it should be.
Note: I can't find your template at all... Maybe it's very old? this will probably not be responsive yet ??
May I ask which Joomla version are you using?
Every CMS, like Joomla, should be up to date. Without this current version, you cannot help, apart from security gaps and possible innovations.
The Joomla 3 version is currently J 3.10.11. Until then, you should first update your website or Joomla! (Very important, learn how to make a working backup of the site in Joomla, to revert to the source in case of any errors and then try again)
If you have this version then almost any template offered here by J51 should do what you need. I don't know your site, I don't know what external extensions you use that are not in the Joomla core. So you have to check it yourself. I think almost all J51 templates are also responsive and display well on mobile devices. Not as "old" as on your current page... (not responsive)
If you install a new J51 template (but that's the case with every other new template) you have to install your modules ect. adjust with the new module positions...
Note: Remember, there is already Joomla 4! Support for J3 will end in summer 2023. Here a larger jump is necessary to keep the page up to date. but there is a lot of information on the web.
Also consider starting from scratch, starting a new J4 page right away and then adding any content from the old to the new J4 page.
There are also extensions, e.g. copy your posts and user accounts from J3 to J4 without data loss...
The template is a bit older, but the problem exists since the beginning of the installation.
Yes, the template is just too old. Maybe the developer can help here but I don't think there is support for the old template?!
At that time, no value was placed on views for mobile phones
