1. milian
  4. Thursday, 13 June 2019
Hi I purchased the Robyn template, and installed it including the sample content.
I am edditing the "Example - Imagehover" but I miss there a target-parameter (_blank) for the URL.
When clicking on a picture i want to open the underlying URL to a new (_blank) page.
Is there a "work around" for this?
Otherwise I have to upload another (component) module to make this possible.
That is a pitty (I like the design of Robyn)
Regards, Milian
Hi Milian
If you are familiar with creating module overrides you can override the module output and add the '_blank' target to item 'a' tag (line 93). If you are not familiar with overrides, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will create the override for you. For our reference please paste a link to this post in your email.
Thanks Ciaran,
I just send you the admin in a DM.
Milian
Hi Milian
Your link should now open in a new window. Note we did not have to create the override after all. An option is available in your module settings (General Settings -> Open link in new widow).
Thanks Ciaran,
It works fine.
I suppose that you will add this feature in an update ,'cause this is an essential addition.
So webmasters can choose the target.
If so I download it immediately...
Thanks again and regards,
Milian
Hi Milian
The feature is available with the latest download of the module with the Robyn template.
Thanks!
