1. tcm1003
  4. Sunday, 21 August 2022
I try to build a new website with Stella (J4 version) and can't get the footer menu displayed. The HTML code is there, but it's invisible.
You can see it at https://aufbau.sultmershagener-sc.de/. Did I miss any settings?
I just worked on it and then I saw your answer was faster ;)
But I found an other solution: as seen in the source code the z-index in the class .body_bg is set to 0.
If one sets the z-index in the class .footermenu to 1 the menu appears.
.footermenu {
z-index: 1;
Should work too ;)
#container_footer {
position: relative;
background: transparent;
.footermenu ul {
padding-left: 0;
