1. eumel7
  4. Sunday, 26 February 2023
I may have discovered a bug in the J51_pricingTable module for J4 (version 1.0).
When you want to add a function(s) in a column, the "+", "-" and "Move" buttons are hidden and only visible with a line... (screenshot)
Can anybody confirm this? Or, ciaran if it's a bug, maybe provide an update?
THANKS
Hi Marco
Thank you for reporting this issue. It is strange that it hasn't been noticed before however it may have arisen from a recent Joomla update.
To amend could I ask you to try installing the attached update. If this resolves the issue, I will update the module across all its templates.
Thank you for the update. Installed it and did some testing. Everything seems to be working now!
The error occurred after an update from J3 to J4 in the riley template. I looked at the files again. I noticed that after downloading the Riley J4 template, under: "Install files" the modules: snipcart, profile and pricingtable are EMPTY (1KB) (see screenshot)
Thank you Marco
It's been a while in coming however I have just created a new update for the Riley template and amended this issue with the release. Thank you for bringing it to our attention. :)
