1. bunsworth
  4. Sunday, 26 February 2023
I’m rebuilding a site in Joomla 4 and would appreciate your guidance on a couple design issues on the home page. The working migration is at:
https://bonnieu23.sg-host.com/
The Original site is at: https://dogclubofhollywood.com
1) The main menu and content area is flush at the top & should be below the logo. The other internal pages are laying out fine under the logo.
2) The hover gallery under the slider needs to have 5 in the row across with no extra space right & left & top & bottom (if any 5 pixels would be fine.) I used a CSS in the previous site which is not working in the migrated site.
the previous custom CSS is:
/* Homepage Gridgallery module position adjustment */
#top1_modules.block_holder {padding: 0 5px;}
.module {padding-bottom: 0px;}
If your issues remain, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I'm going to restore a backup and reinstall the template. Thanks.
Still need help.
#1- can’t find your suggestion solution anywhere.
The header is NOT set to sticky.
As per the template sample, the header should be falling below the logo position as the default. Am I missing a setting to control the header position?
#2
I was able to delete padding as you suggested, but 3 more problems remain.
a. The columns are set to 5- and they should auto size for 5. But they stay at 4
b. The hover background color is set to green and it appears transparent.
c. None of the hover effects work.
Your guidance is appreciated.
1. Does disabling the General Settings -> Overlap Header if in showcase-1# module position option in your slideshow module settings give you the desired result?
2. Try enabling the Remove Container Padding option in the Module Widths -> Top-1 tab of your template style settings
