1. zoki
  3. Thursday, 02 July 2015
Hi all
Does the Module have to go all the way, or is it possible to shrink it in a way, so it just reach as long as the a title in it for example?
thanks in advance
Zoki
Hi Zoki
Presuming I understand you correctly you can manually edit the widths of your modules by using the 'Module Widths' option in your templates parameters. For further details please check out.. http://www.joomla51.com/tutorials/item/understanding-the-module-widths-options
