1. Hans
  3. Friday, 24 May 2013
I have problem when I am trying to use the module variation. I am trying to have an icon (mail) and the result is that I get 3 icons (I suppose that the correct one is the one connected with the module name) and that the column width is affected (becomes very narrow).
Another thing is that the "read me" button is just text - Read me... What is the trick to get an ordinary button or the nice blue one in the bottom of your demo.
My environment is Joomla 3.1.1 and your version 3.0 of Metropolis.Use the url http://www.drewitz.se to see the result.
Hi Hans
There appears to be a space just before 'icon-mail' in your Module Class Suffix. Could you check if this is the case? If so removing the space should amend the issue.
Would you have a URL to an example of your 'read more' button?
Hi Ciarán
Thank you for your answer. The problems with the icons are solved now as you can see (url: http://www.drewitz.se).
You can use the same url to see the read moore... text.
Once more thank you for your help!
Hi Hans
Thank you Hans
I have edited your button CSS to include the Newsflash module read more buttons. The read more buttons of your newsflash modules should now be appearing the same as your article read more.
The button you indicated on your email is from the ImageLinkHover module included with your template. I have installed ans set up an example of this module in the bottom-1c module position.
All should be now working correctly.
