1. tbcomputerguy
  3. Thursday, 18 April 2013
I have setup an alternate site to test things on, to get this responsive site working better. When viewed on a mobile phone, the menu's first item selects an item in the middle of the menu. Why does in not select the first menu (furthest left). It starts with gutters, which is somewhat unappealing.
http://elementsnorth.com/elementstest/
Strange...
Could I ask you to try replacing the following in your templates scripts.php (../templates/j51_metropolis/php/scripts.php)..
<!-- Hornav Mobile (converts menu into select list) -->
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/js/mobile/selectnav.min.js" charset="utf-8"></script>
<script type="text/javascript">selectnav('mobile');</script>
window.addEvent('domready', function() {
selectnav('mobile', {
label: '--- Main Menu ---',
nested: true,
indent: '-',
</script>
With...
nested: true,
indent: '-',
autoselect: false
</script>
Will do, I will keep you posted....your the best
No luck cirian. Still shows up the same. what if i convert it to a module?
Hi David
I don't believe changing to a module position would make any difference. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Not sure if you tried to log in, but i forgot to enable you. Sorry
Ciaran, i fixed it. When we had the novation template, we installed the third party extension mobile joomla. I got to thinking that there must be a third party extension. I uninstalled it and voila the menu works.
Dave
Nice one.. I don't think I would have thought to check for something like that!
Thank you for the update.
