1. tbcomputerguy
  3. Wednesday, 17 April 2013
Is it possible to remove the metropolis logo completely. I will then be able to put my logo in top a, b,c. As it is right now, the logo is aprox 960 by 147. when switching to responsive, most of it is cut off. I thought i would cut it in 3 and then the page might render better on small devises.
Hi David
To remove the logo area including the white background try adding the following to the Custom CSS field of your templates parameters..
[code type=css].logo_container {display:none;}[/code]
Thanks cirian worked perfect. Now i have another question in the forum about the menu.
This did not work for me - Joomla 3.1. http://trailswestrvpark.com/index.php The logo is gone, but the space remains.
I also unsuccessfully tried:
#logo {
display: none;
Hi..
To completely remove this area try also adding the following to your Custom CSS field..
#container_header .wrapper960 {
height: 80px;
Yes - that did the trick. Thank you.
None of these work for me with Privilege.. any suggestions? thanks
a
Hi A
Would you have a URL to an example of your template and logo?
