1. FCPeggy
  4. Monday, 11 July 2016
Hi, I love this forum.
I found part of the answer to my question from a previous post - to get my logo to be responsive to hand held devices with this custom code you provided:
@media only screen and (max-width: 534px) {
#logo {
background: white;
.logo > a {
background-size: 700px auto !important;
But I find the logo doesn't center horizontally but goes to the top of it's space. Is there an adjustment I can make so it actually centers from top and bottom too?
Many thanks for you help.
Would you have a URL to an example of the above screenshot?
This is a test build on my laptop - it's not online yet. Any ideas would be welcome or suggestions of what I could research would be appreciated. My only other thought would be to play with top, bottom adjustments - can this be done using a percentile?
A bit of a shot in the dark this but maybe something like the following (Custom CSS field)...
h1.logo a {
background-position: 50% 50% !important;
Got it - thank you for you help!
Using the recommendation to use the Metropolis logo image installed at the root directory, I made sure my logo did not exceed the "Metropolis" logo image size. Then your added code to what I found centered within top and bottom space.
Again, EXCELLENT support. I will be purchasing more of your templates MOST DEFINITELY! Joomla51 Rocks!
.logo > a {
h1.logo a {
Excellent... thank you for the update and for sharing your final solution! :)
