1. KChev
  4. Sunday, 02 March 2014
I've been successfully using a plugin for Google Maps on your templates but the exception is Metropolis. The map does not show at all, though the parameters are identical to the maps on the other sites. Is there some special code I should know about?
Thanks in advance.
Kim
Many thanks!
Thank you Kim
Your Google maps extension appears to be conflicting with the animated dropdown menu script of the template. As you don't appear to be using this script I have disabled it by removing the following from your templates scripts.php (../templates/j51_metropolis/php/scripts.php)...
<!-- Hornav Dropdown -->
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/js/dropdown.js" charset="utf-8"></script>
window.addEvent('domready', function() {
var myMenu = new MenuMatic();
</script>
All appears to be now working fine :)
That is rather strange. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Here is the Metropolis site where it doesn't show: http://www.lepalaisdesevequesdecomminges.com (click on Accès or Access)
Here is a Renovate site where it does work: http://www.gites-anilac-ariege.com (Accès/Access)
Hi Kim
