1. ziggy
  4. Tuesday, 11 December 2012
Hi all
when I want only 1-2 news on main site I goes to setting:
but when I set leading Arcticle to 1 these error raise:
Warning: Illegal string offset 'active' in /var/www/ud06_53/html/lb_portal
/templates/j51_arkadia/html/pagination.php on line 95
Warning: Illegal string offset 'active' in /var/www/ud06_53/html/lb_portal/templates/j51_arkadia/html/pagination.php on line 101
Warning: Illegal string offset 'active' in /var/www/ud06_53/html/lb_portal/templates/j51_arkadia/html/pagination.php on line 95
by set it on 2 it is ignored and all news (currently 3) are displayed. any idea whats going wrong?
Hi Straight Shooter
To amend try deleting your templates pagination.php (../templates/j51_arkadia/html/pagination.php)..
If that doesn't recolve the issue may I suggest sending temporary administration access to your Joomla installation and we will examine the issue furhter.
hi, did you need user for cms admin or ftp admin or both?
If you could send both we will amend both issues for you. FTP access can be to your templates folder only.
mail? or have this forum PM? I don´t see it
Sorry thought I had mentioned the email address in a previous reply. You can send the information to [email protected]
thx, send! :)
found one more think at this case:
when you creat sub category and create a new entry with this sub to display on main side, it is not display. only the main/root category
Hi Mike
Not sure if I understand you correctly. Would you have a URL to an example of this issue?
you can take the login I send you,its still vialid for this:
how you can see, I have set one main category "News" and a sub "World of Tanks"
when I now set to a article the sub category, with flag "Featured=Yes" for main page, it is not displayed. only when it is in the main category
I expect, when I select Featured = Yes that it is displayes on main blog, equal which category
Hi Mike
I believe by default Joomla will not show articles in sub categories with the 'Featured Articles' menu item (to confirm this maybe switch to a default template and refresh the page). Have you considered using a 'Category Blog' menu item instead?
yes you right, sorry! was running joomla 1.5 before we switch now to 2.5, there it was possible how i was expect it here!
at this position, thanks for you great support!
