1. hpi
  3. Monday, 17 September 2018
Hello.
I make a new website with valencia template and i have a bug in the menu display.
i give you the URL for a better comprehension:
http://vzdkdu6053.phpnet.org/colmiane/index.php
In the menu on the top, hen you want to go on "guide pratique", the case with all the subcategory go to the right and isn't readable. How can i do to fix this bug?
Thank you !
  1. http://vzdkdu6053.phpnet.org/colmiane/index.php
Because of some restrictions to the column-count CSS property, the only solution to amend this is to change the position of the submenu parent item (commerces). Changing this item from 4th to say 1st or 2nd should resolve this issue.
Hello Ciaran.
Thank you, it is partialy good.
I added your code and now in the "guide pratique" category, if you go on "commerces", ther is a problem.
What can i do to solve it?
Thank you !
.hornav > ul > li.item-573 > ul {
left: auto !important;
right: 1px !important;
