1. KolfKord
  3. Friday, 06 July 2012
Good evening,I bought the Twilight template. But I found a bug in the menu ...On this site: http://makersitaly.it/ if I go to Exhibitors> Registration and Payments go into the menu under the submenu closes many times. Without being able to enter into any page of those listed ... Is there a workaround for this bug?
Hi KolfKord
It seems your hornav menu may not be set up correctly in particular adding moomenu to the Menu Tag ID within your menu modules parameters (Extensions -> Module Manager -> [YourMenuModule]).
thanks for the answer. I did as you said ... Fixed image as attachment? For the moment it seems to work! But for those spaces and the other from a menu instead? Visually it is ugly ...
Hi KolfKord
Your menu still doesnt appear to be working as it should. May I suggest sending temporary administration access to info@joomla51.com and we will investigate this further.
User created. Thank you very much indeed ... I do not know why they have problems ...
Thank you for the access.
Everything should be fine now.
My fault actually as I hadnt realised it was Joomla 1.5 you were using which has slightly different menu settings.
Thank you! You were very kind!
