1. Oliver
  4. Wednesday, 10 February 2016
I have a little problem with the menu on Artisan template.
I use 3 levels in this menu. The main level, a submenue and a sub-submenu.
If I click on the main menu the submenu opens - fine.
But if I click on a submenu that has NO sub-submenu items, all items in this main menu open.
Maybe its a bit confusing so I try to show.
That is the catalogue part of our current menu:
Unser Produktkatalog.....................<= MAIN Level
...Bestellung aufgeben ?................<= SUB menu - clicking here, alle menu items open
...Übersicht Produktkategorien.......<= SUB menu - clicking here, alle menu items open
...Waschbecken..............................<= SUB menu - clicking here, ONLY the 4 SUB sub menu items of this point open
......Waschbecken / Gengafloor.......<= SUB SUB menu
......Waschbecken / Steinputz .........<= SUB SUB menu
......Waschbecken / Steinzeug.........<= SUB SUB menu
......Waschbecken / Raku................<= SUB SUB menu
...Garnschalen................................<= SUB menu - clicking here, alle menu items open
...Schalen........................................<= SUB menu - clicking here, ONLY the 2 SUB sub menu items of this point open
......Schalen / Raku.........................<= SUB SUB menu
......Schalen / Steinzeug..................<= SUB SUB menu
What can I do that the menu items open correctly?
You can check the current problem here: http://test.keramikatelier-schoening.de
Thanks in advance
Oliver
Great!
Thank you for the update.
Awesome Ciaran - works as excepcted :)
Thanks once again for a quick and capable support !
Oliver
Thank you Oliver
Adding the following to the Custom CSS field of your templates parameters appears to have resolved the issue...
.hornav li.active ul {
display: none;
.hornav li.active > ul {
display: block;
HI Oliver
