1. Prasch
  3. Tuesday, 07 March 2017
how can I set the menu titles reight of the logo more left?
See my site: https://www.limo.bayern/
Another Problem is, that the submenu titles are not hovered. Where is the problem?
Thanks,
Robert
  1. https://www.limo.bayern/
Hi Robert
Presuming I understand you correctly you could try adding the following to the Custom CSS field of your templates parameters...
.hornav > ul > li.item-166 {
float: none;
You wish to add a hover effect to menu items in your dropdowns?
Hi Ciarán,
thanks. I added the Code under the template point "Custom CSS". Now the third menue point ist on the right side.
But how can I get the menue points closer to the logo/middle?
Regarding my second question. I meant mousover.
I found where to configure, but the mouseover colour seems to be fixed to white.
Is there also a possibility too change it?
Thanks,
Robert
Hi Robert
.hornavmenu {
box-sizing: border-box;
padding: 0 80px;
To set a mouseover color to your dropdown item you can also add the following (edit to taste)...
.hornav ul ul li a:hover {
color: #CCCCCC;
