Hello Ciaran, we have two questions
1. we use Kaylee template at the website casaderosa.gr and on slide out menu layout the menu can go back only on the first screen
if you scroll down anywhere and open the menu, it cannot return to the right, you can ony navigate if you click on a menu item
2. we use Stella template at the website oskarsapartments.com we know it is NOT an easy task BUT, is there a possibility to put the logo at menu bar that follows when scrolling, again on mobile view. it probably needs a module position but it worths to ask
