1. sjudelson
  4. Sunday, 08 March 2015
I have the Substance template. The hornav menu does not show the drop down menu items. Reading several forum entries, I understand that the hornav menu relies on a hover state to trigger the display of sub items, and may not display on some mobile devices. Because of this, I read that you recommend to use the mobile menu across all mobile device screen sizes. How do I do this? I don't see this option to enable a mobile menu. Is there a better alternative? Thank you!
Of course. Amagansettseasalt.com. Works (and looks great) on my PC and my Android phone. On my iPad, however, the drop down menus do not appear. Thank you!
You appear to be using an old version of your template along with an old version of joomla. May I suggest downloading the latest template from your 'My Downloads' and install via your extensions manager. This should resolve this issue for you.
I installed the new version of the template and it works perfectly now. Thanks, Ciarán!
