Jumping back in here to see you received my last message and share some updates.
- We've tried both the default menu setup, and with a menu module in the hornav position.
- The mobile menu and comments work fine together with other templates.
Thank you for the update. Ok I think I might have found the issue. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
